On 3/22/2024 at 12:19 PM, Dustin said:Sorry to hear you are having issues.
It sounds like a flow sensor cable is loose or unplugged.
These would be the plugs going to the feeders on the back of the machine.
Dustin,
Thank you so much for your prompt response. I removed the feeders and checked the flow sensor connections. They both looked fine, but I pressed at them a little anyways just in case. Unfortunately, that didn't solve the issue.
I'm trying to get the event log, but since I can't connect to the printer, I can't see it. Any other possibilities?
Dustin 132
