My guts say i should not use more than 2Nm for this, but i could be wrong too since i habe no experience in this section.
The anycubic support gave me a great recommendation: if the nozzle can´t get tighter, make it tighter.
If i follow this i have a two part nozzle very soon.
I also can screw it in with the regular wrench that was included, but i have almost no feeling in my right hand if something is thight or loose, i got a nerve damage there so i am depended on torque wrenches.
GregValiant 1,253
You have a lot of thread engagement there. The specification for a steel M6 into a steel thread is 3.84Nm. The weak point is threading them into a soft aluminum block.
Repeatedly changing nozzles and tightening them will shorten the life of the block as eventually the threads will strip. The brass of the nozzles has much higher shear strength than the aluminum heater block. The nozzles will eventually win. The only real fix is to put a threaded insert (heli-coil) into the heater block.
For the short nozzles in my hot end I use the precise specification "Snug". As long as molten plastic can't get by you are good to go.
