Does the printer select have the specific printer dimensions pre loaded?
Go to solution Solved by Slashee_the_Cow,
  • Solution
Posted · Does the printer select have the specific printer dimensions pre loaded?
If you added the printer through the Add Printer wizard in Cura, then the print bed dimensions should be correct and you don't need to do anything.
Why, does something not seem right?
