Oh I didn't know the USB was an obsolete feature, that would explain why there is no option to search for the printer via USB.
I was hoping to reduce the need to copy Gcode files to memory card and then plug the card into the printer, but if that an out dated method i guess I'll just have to do it manually like I'm currently doing.
I haven't used the printer in about 5 yrs, it's just been sitting in my study gathering dust for the most part( i did start a Dr Who chess set back when i bought it, that turned out pretty good), I recently move house and have set the printer up again in the new study and after redoing the leveling process and printing a few items including a wall mount for my Lego International Space station and a couple of cookie cutters as test pieces, it's working like new.
I would like to get a printer that has the ability to use flexible filament, but current don't have space for a new printer and from what google showed me, they are somewhat more expensive, like 3 times what i paid for the Aldi model.
Anyway thanks for the reply.
Slashee_the_Cow 272
You shouldn't print over USB, which is required for keeping track of print progress like that. In Cura, USB printing is a legacy feature and is no longer maintained. It's a relic from the days when printers were too stupid to even read a list of instructions from a memory card so needed to be fed them one by one by a computer.
You could set up software like OctoPrint on a dedicated system (a Raspberry Pi works great, and is pretty cheap) which is about the only acceptable use for USB printing these days (since you don't have to worry about your main computer freezing or something and screwing up your print, it's on a different system which is designed with exactly that not happening in mind), and use a webcam to monitor your print remotely (great for seeing if something collapses when you'd really rather it wouldn't).
While it's technically possible, I'm not aware of any software which actually does have the feature you describe.
Also, if you got that from Aldi in 2016 and it still works, I'm impressed. None of the electronics I ever bought from them lasted even half that long. Hence my use of the past tense there.
