Thanks, I will post the project file when I'm back home & can access the computer.
Here is my project file. Thanks for the help.
CE3E3V2_y axis rod holder left.3mf
Edited by neighbordIf you set Support > Support X/Y Distance to 0.4mm, it does support the whole thing:
It's just that the gap between the sticking out bit and main body is small enough that any higher gap won't fit in there. The problem with setting the support distance to that is that not only is it harder to remove, but you get a lot more of it than you need:
Fortunately these things can be targeted: create a support blocker, move and resize it to fill the area - doesn't matter if it's a little bit bigger on the X and Z axes as it needs to be, but thanks to support horizontal expansion needs to be a little bit smaller on the Y axis:
Now with the blocker selected open the Per Model Settings on the toolbar and turn it into the third option (Modify settings for overlaps) :
Click the box that says Infill mesh only and change it to Cutting Mesh:
Click Select settings and in the box that comes up search for the Support X/Y Distance setting and check that, then click Close in the bottom right:
Now change that to what we (you're my silent partner here) figured out before was small enough to fit into the gap (0.4mm):
Now switch back to Preview mode and admire our new, localised, tight gap filling support:
I'm including the file where I did it but you'll learn by experience if you follow the steps yourself.
@Slashee_the_Cow Oh thanks a million for the excellent analysis. I've been laid up with illness for a few days, but will try the suggestions. Cheers!
Slashee_the_Cow 382
If I had to guess it's that the Support X/Y Distance is preventing the support from getting close enough.
If you could post your Cura project file (.3mf, in Cura get it ready to print then go to File > Save Project) then we could have a closer look and play around with the settings to see if we can find something that works.
