I've had the same issue with this specific error. Previous print ( a couple hours prior) did not generate this error.
- Loaded STL from thingiverse
- Adjusted size (increased by 125%)
- Sliced
- Sent to cloud attached printer (again, been printing fine up to now)
- Just checked an Printer shows off line, which has happened before but has not returned this error.
My log is attached.
Slashee_the_Cow 621
It would help if you could provide a bit more information (like what are you doing when that message comes up?) and also if you could post the Cura log file (in Cura, go to Help > Show Configuration Folder and the file is cura.log) that would give us something to dig through.
