Why does Cura not support a Creality K1 Max 3D Printer?
Posted
· Why does Cura not support a Creality K1 Max 3D Printer?
While I can't speak for this instance in particular, profiles for printers not manufactured by UltiMaker are contributed to the Cura code repository by either their manufacturers or (more often) community members.
Cura does not come with a profile for the K1 Max, which could explain why it will not connect (connecting over a network is not something I'm too familiar with since I've never had a printer which does it).
It's possible someone has posted a working profile or instructions for how to get it working somewhere else online, I suggest searching to see if anyone has.
Posted
Direct Network printing in UltiMaker is generally only supported on UltiMaker 3d printers.
Connection to 3rd party printers usually comes from a 3rd party plugin from the marketplace.
Again, for the same reasons as noted by @Slashee_the_Cow
TLDR;
Support for K1 Max is missing, because no one bothered to contribute the support.
Try asking Creality why, its not UltiMaker's responsibility.
Slashee_the_Cow 272
Dustin 130
TLDR;
