UltiMaker is not responsible for adding support for third party printers to Cura.
Manufacturers or the community are welcome to contribute them to the Cura source repository, so you are probably best off contacting Creality, or searching the web to see if someone else has created one.
If you printer is similar enough to an existing printer you can usually use that and just change things like build volume if necessary.
Slashee_the_Cow 269
