Here find the File , Thanks for the help😁
GregValiant 1,255
You have made a lot of changes to the "extra fast" profile and you have never reset it back to defaults. All your changes are still there.
There is no need for "one at a time", you have "spiralize" turned on which means "remove all holes" is turned on. Lots of stuff that will cause problems with this model.
Click on "extra fast" and re-select it. When asked, click on "discard all changes".
I would suggest staying in the "custom" settings view rather than that basic one. You have to give very model it's own love.
I switched to "fine" since a small model like this can benefit from the lower layer height.
Edited by GregValiant
- 1
GregValiant 1,255
Models can have errors that seriously affect the slice.
With the model loaded into Cura and Cura ready to slice, use the "File | Save Project" command and post the resulting 3mf file here. Someone will take a look.
