Posted
· Problem with line thickness and width in CURA
If you could post the project file (.3mf, in Cura get it ready to print then go to File > Save Project) that would give us something to chew through.
Off the top of my head I would just say make sure that Experimental > Use Adaptive Layers is turned off (if you can't see the setting, just search for it and it'll show up).
Slashee_the_Cow 269
