How do I find the folder for the CuraEngine Tiled Infill Generation plugin new infills?
Probably need to restart Cura to get it to pick up the new pattern.
In case the configuration folder doesn't show up, for a Mac:
Quote
Macintosh HD\Users\[user_name]\Library\Application Support\cura 'Library' is a hidden folder. To navigate to it quickly in a finder window, click 'Go' in the menu, hold 'ALT' to reveal the library window
Slashee_the_Cow 269
Go to the Cura configuration folder (in Cura go to Help > Show Configuration Folder), then you want to go to:
plugins\CuraEngineTiledInfill\CuraEngineTiledInfill\tiles\
