- Solution
fuermi,
"Display Info on LCD" is located under add script at the bottom right of Cura. You can set various items to display here.
fuermi,
13 hours ago, Muskateer10 said:fuermi,
The post-processing script button only appears at the bottom right of the window if you already have any scripts enabled. If you don't, you get to it through Extensions > Post Processing > Modify G-Code.
Slashee_the_Cow 268
All of the old scripts for displaying information on the screen have been replaced by Display Info on LCD (which is included in Cura 5.7). Could you please open the post-processing window, click the button to add a script and take a screenshot so we can see what scripts you have available?
