Posted (edited) · UM3 - Dimensions of rivet nut that holds feed unit/feeder to body
Hi all,
Stripped this from the github UM3 assembly as I need to make a couple up (the second hand machine I just bought had nuts and bolts in place of this rivet nut  - meant I had to strip down the LHS of my Ultimaker to reattach the feed unit to retrieve the loose nuts and washers that fell into the cavity.)
Please see attached dimensions to save you the work. I'm not going to bother stitching in the teeth, just hot melt glue it into place.
Admin - if there is a better title, please feel free to change it.
Regards,
A
Edited by Andrew_F
Correct name of rivet nut
    • Andrew_F changed the title to UM3 - Dimensions of rivet nut that holds feed unit/feeder to body
          • Heart
        • 4 replies
