Posted · Why cura delet my walls in 3d model
Blender was not designed to produce "printable" models but it can be used.  You need to be careful and check the model closely before you export it.
You might have surfaces that are facing inside-out, or there might be open seams, or extra internal surfaces.  If you are working on a Windows system you can go to the Microsoft store and download "MS 3D Builder" which has a pretty good repair utility.
You need to figure out how to make the adjustments in Blender or this will keep happening.
