From what i can tell these logs are all for Dremel slicer not UltiMaker Cura.
You will need to contact Dremel for help with that.
As for running UltiMaker Cura it might be possible Dremel is using the same system directories as UltiMaker Cura (this has been noted to happen with other brands) which corrupts the UltiMaker Cura files.
UltiMaker and most of the community here isn't able to offer much advice for unofficial releases of UltiMaker Cura.
I don't know how well it might fulfil your needs, but for regular Cura there is a plugin for Dremel printers available in the Marketplace (button at top right of Cura).
Dustin 130
