There is a post processor called "Search and Replace". You would need two instances.
Search = M204
Replace = M8008
and
Search = M205
Replace = M8007
Those will work as long as the units are the same and the parameters are the same. Cura will use the S parameter for Accel. Other parameters for Accel would be X and Y for each axis or P and T for print and travel. You might have to get fancy with the regular expressions if there are numbers between the parameters.
Jerk is by axis so it always uses X Y parameters.
I think Search and Replace will start at the first layer (raft or model) but you'll need to check to make sure.
Search = M204 S(\d*)
Replace = M8008 P\1 T\1
Use Regular Expressions = checked
would go from
M204 S1000
to
M8008 P1000 T1000
GregValiant 1,259
Search = M204
Replace = M8008
and
Search = M205
Replace = M8007
would go from
M204 S1000
to
M8008 P1000 T1000
