How to fix blobs when slicing in Cura - Does not happen in other software
Posted
· How to fix blobs when slicing in Cura - Does not happen in other software
Your 3mf file only contains a model. Please save a Cura project file (get it set up then go to File > Save Project) and post that so we can have a look at your settings and such.
Slashee_the_Cow 280
