I don't see "CustomSupportCylinder" in the marketplace plugins for cure 5.6 or 5.7. I did got to help and look at configurations folder and it shows the plugins I download today.. I can find a plugin for "CustomSupportCylinder" or "Part for Calibration".
Thanks for the continued help..
GregValiant 1,330
There were conflicts with Cura since 5.x came out so @Cuq has pulled them from the MarketPlace. I'll let him address whether they will be back or not.
I use the Cylindrical Support shapes a lot. I copied the "CustomSupportCylinder" folder and its contents from the 5.6 "Plugins" folder to the 5.7 "Plugins" folder and Cura 5.7.1 found it the next time I ran the program.
You can use the "Help | Show Configuration Folder" command and you will see the "Plugins" folder for that version of Cura.
mathis58 0
Thanks. What about the Part for Calibration plugin? Both worked fine in cura 5.6.
