S5 Printer will not give option to connect to difgital factory
Go to solution Solved by Dustin,
Posted · S5 Printer will not give option to connect to difgital factory
It would appear that all those ports are already open. As for whitelisting the domains, I am not sure how to find that setting.
    • Solution
    that looks like a screenshot of windows firewall?
    This issue would be related to your network router - basically your printer cant connect to UltiMaker servers.
    Otherwise please open a support case with UltiMaker directly, and send them your machine's log file it will tell them exactly whats wrong.
    UltiMaker does not provide direct support via the community.
    Contact here: https://support.ultimaker.com/s/contactsupport
