Issues with Ultimaker 3 and versions of Cura pass 5.0
Posted
· Issues with Ultimaker 3 and versions of Cura pass 5.0
The gcode from 5.7.1 is using a shorter initial layer height - 0.2mm vs 0.27mm in the slice from 5.0. That could lead to adhesion problems (higher flow in first layer = better stick).
By the looks of it you're using a quality profile only slightly modified from the "fast" preset - it's possible the preset was changed at some point.
Slashee_the_Cow 382
