Posted (edited) · Cura 5.7.1 doesn't look "right"
I'm not really sure how to explain this, but Cura doesn't look like I expect it to look. For example, when trying to scale a model, there's no place to enter in a particular size in the XYZ area. When sliced, there's no sliders to let me look at a given layer or extruder position. When I am in  slicing mode, I used to be able to hover over the various settings, and I would get a popup that graphically explained what these settings did. That's not there anymore either
Something isn't right, and I have no idea how to get it to look like I am expecting it to look.
Help!
Edited by Lancer525
    Posted · Cura 5.7.1 doesn't look "right"
    • Did you download the new version through the links on UltiMaker's website? Some printer manufacturers have their own versions of Cura which follow the same version numbers but are modified to suit their needs (or in some cases... just cause they can).
    • What version were you running before?
    • What OS and version are you running?
    • Have you tried 5.7 or 5.7.2?
    • Did you uninstall whatever previous version you were using, either before or after installing 5.7.1?
      • If you didn't, does the previous version work as you expect it to?
    • Have you tried reinstalling?
    • The help popup with the graphical explanation of settings is probably the "Settings Guide" plugin available in the marketplace (but it should appear in both Prepare and Preview modes when editing the quality settings).
        • 7 replies
