16 minutes ago, Dustin said:cant see from your pictures but usually that points to a damaged limit switch
(bent arm, etc)
I thought that as well, but it seems to have no issue homing or preforming a switch test.
Is there a separate limit switch it uses during printing or something different that would make the one that usually works not work in this case?
Dustin 146
(bent arm, etc)
