Cura on multi-monitor Windows setups
Posted · Cura on multi-monitor Windows setups
It would be SO useful to be able to move the settings panel onto a separate monitor and leave it open and expanded, like with 3DS Max where I can put the command and layers panels on a separate monitor and not have them covering parts of the main window. Continyally closing settings to reveal the slice button is a real pain!
    There's a widget at the bottom of the settings panel you can click and drag to change its size so it doesn't cover the slice button:
    As for putting it on a separate monitor entirely, you should probably submit a feature request for that.
