Z Seam holes
louis_sckr
Posted · Z Seam holes
Hi @Torgeir,
yes, I did that. But I think my collets are worn out. It still moves slightly but its definetly improoved.
Do you mind sending the 3mf, so i can see where you did put the support blocker?
Thanks, Louis
    Posted (edited) · Z Seam holes
    Hi @Torgeir,
    I already cut them but I think the blades are worn. At least the bowden tube still moves a bit. It got better for sure but i think new ones with new collets is the best solution.
    Do you mind sharing the 3mf with the support blocker so I can have a look where and how you placed them?
    Thanks
    Louis
    Edit: sorry for double response. It didnt show my response until now, so I rewrote it.
    Edited by louis_sckr
