Movement of extruder motor (even without filament) causes temp reading to artificially dip and overshoot
Posted · Movement of extruder motor (even without filament) causes temp reading to artificially dip and overshoot
This is a very strange thing. I've been haunted by this issue by an original Ultimaker and an Ultimaker I built myself. I've had some intermittent temperature stability problems. In diagnosing this issue, I have discovered that when the extruder motor (and possibly other motors) is driven even without filament, the temp reading drops ~5C immediately. The temp controller compensates for this artificially low temp and pumps up the power. The instant the extruder motor stops driving, the temp snaps back up ~5C but by then it has overshot. This has happened on multiple Ultimakers with different hardware. I originally diagnosed it as a blown up stepper motor but now I'm not so sure.
    Indeed interesting. Sounds like cross talk or (partial) short cut somewhere. Maybe you can check / answer a few things:
    - Do you use an original UM shield PCB or a legacy board?
    - Are the wires of the motor nicely twisted?
    - Do the motor wires run in parallel with the sensor wires?
    - Does the effect exist for any motor, i.e. also for x, y and z axis?
    Ultimaker 1.5.7 shield
    motor wires are twisted nicely
    motor wires do run in parallel with thermocouple amp board's power and signal wires
    I'm still experimenting with other motors' effect
