Posted · Bio printing
Anyone adapted the UM1 kit to print biological samples? (cell scaffolds, cells, proteins etc.)
Would love to hear what you've done/attempted, especially any success stories!
Jono
    • 2 weeks later...
    Can't say if it would be. I suppose if you kept the head mass very low (eg. 5cc syringe) and printed slowly, with a fine enough needle gauge, you could exceed the precision you'd get with plastic. Are you thinking of printing into agar? I saw where someone printed into jello with a syringe, so you might even be able to get around overhang problems if you programmed your STL to retract the syringe and print in voxels instead of dragging it around.
    I am actually not planning to print in agar for the moment, but to use biopolymers and write with a very liquid water solution and then let it dry slowly before the next layer. Speed is not an issue, I am more concerned about resolution. Thanks for the advice!
    for anybody following this thread, I recommend this:
    http://wiki.ultimaker.com/Bioprinting_with_the_Ultimaker
          • Heart
        • 4 replies
