Switching from Repetier to Cura - missing Z-height option?
eduard.dk
Posted · Switching from Repetier to Cura - missing Z-height option?
My printer is a PrintRbot Simple Metal.
Instead of adjusting the Z height on the bed level sensor (which is a bit difficult) I use the Z-height setting in Repetier to add 0.2 mm to all Z values.
I can't seem to find this option in Cura. Any ideas?
(It is soo much easier to calibrate in software).
Best wishes,
Peter
    Currently I am using a workaround in Gcode - which I hope works:
    G1 Z0.2 ; move to 0.2 mm above Z=0
    G92 Z0 ; set the current position to Z=0
    Best wishes,
    Peter
    Just so you know, you can also do this adjustment in firmware, as well as the above start-code trick.
    Cura won't get a setting for this. As I think that it's not the job of the slicer to adjust for this.
    Thanks for the answer.
    You think calibration should rest solely on the machines?
    Anyhow - yes, I suppose I could get it to work with simply storing the value in the firmware.
    Did not think about that. ;)
    Ideally, yes. That's why people are slowly moving towards material settings in the machine (like filament diameter)
