I executed printrun.bat; program Printer Interface (no version number, presumably the latest download) ran successfully for over an hour, then the x-y-z drives ran normally but the PLA feed stopped.
So, which parameters control:
1) extrusion speed
2) x-y print speed
3) x-y travel speed
and, if the PLA feed stops after a longer print time, is this a feed speed or a temperature problem? I have the PLA spool on ball-bearings, so there is very little front-end resistance.
thanks, EM
Daid 303
Did the printing just halt? Or did it slow down a lot?
Also, did you print from Cura or from PrintRun? I recommend printing from PrintRun as that is a bit more stable I think.
