Cura ignores part of print
lbeentjes
Posted · Cura ignores part of print
I tried printing a iphone case. But when it was finished it missed a support wall.
I dont know if its a mistake in CURA or the model itself, but in cura layerview it also doesnt show that it will not print there. Only the last 2 layers it will print leaving some flying PLA. This is the model im trying to print: http://www.thingiverse.com/thing:51533
DSC00606DSC00607
    Usually, this happens if the wall thickness is close to 0.4mm. Try the fix horrible options in the expert settings. With the layer view you should make sure that each line is drawn properly.
