J-head on an Ultimaker?
Posted · J-head on an Ultimaker?
I got my fingers on an original j-head MK V Hotend, and it seems like a great product, very small/compact and seems pretty robust...
Has anyone ever put one of these in the UM original?
If so, how were the results?
    Aren't these designed to have the extruder mounted directly on top of them?
    Afaik there is no interface on the J-head to mount a Bowden tube, so you need to have a somewhat more complicated printhead design than for example with the E3D Bowden hotend. I had a look at the J-head (and clones), but that's why I chose the E3D in the end...
    I dont know...
    The one i got has a screw (called umbraco in DK, dont know if thats an international title...) in the top that can be taken out so the top has internal threads...
    A few pictures:
    So im guessing if one could find a coupling that fits the diameter and threads it could be used straight out as a very compact little bowden hotend..?
    Would the diameter allow you to cut the threads directly into the bowden with a die, and forgo a coupling entirely?
    Sadly not, already tried... I think the thread is M8, the bowden tubes i have both measure just around 6 mm. on the outside, so they are actually quite loose in the hole...
    Also i kind of like the push fittings, and how you can easily remove your bowden from them... That gets alot harder if the bowden is screwed directly into the hotend...
