Sometimes cleaning stringing residures takes longer than printing itself. I use Paul&Florian's (great) settings with small changes. And those settings have all antioozing parameters in material definitions/jumps section zeroed. Sure low temp settings decreases ooze but doesn't eliminate it. It would be great to see this updated and have ooze-free printouts.
As to the problem you described I assume you play with push-on speed, pull-back speed and travel RPM settings. And push-on does not extrude enough material after the jump. Right?
The Pull-back Speed and the Push-On Speed determine the RPM rate with which the material is pulled back before the jump and pushed forwards again after the jump.
I started to wonder what does it mean "before" and "after" the jump. For how long are those RPMs executed? After all the jump is executed immediatly after extrusion ends.
I thought that maybe that is the time when Z-Jump is executed? So if the Z-offset is set to zero pull-back and push-on are effectively ignored and only travel RPM works.
To verify this I created in Netfabb two small cubes with a gap between them to make jumps and generated g-code (standard quality, hollow object) for them with the following settings:
You can clearly see z-offset before and after the jump (Z2.2500 -> Z3.2500 and back). But correct me if I'm wrong: extruder did not pull any filmanet. Pull-back value was ignored!
I did the same code for no z offset with the same result - no fiament retracting.
The only way I could make E values decrease was to set negative Travel RPM. At Travel RPM = -2 RPM code looks like this:
Fiament is retracted during the jump. But since there is no push-on after the jump extrusion starts with smaller E values than before the jump and thus with void in the nozzle.
That would explain the situation you describe, wouldn't it?
It's late and I might be missing something huge but it seems that push-on and pull-back settings are ignored altogether. That would be bug that makes restart of extrusion after a negative travel RPM jump impossible :-( Can anybody check my reasoning?
On top of that there is no comb feature in Netfabb - that makes stringing even worse.
konrad 0
Hi Makerswamp,
Netfabb's very laconic manual here
http://wiki.netfabb.com/Material_Settin ... for_RepRap
says:
Jump speed 180mm/s
z-jump speed 20 mm/s
pull-back speed 400 RPM
z offset 1mm
push-on speed 400 RPM
Travel RPM 0 RPM
The result for one of the middle layers:
Edit: Only after writing the above I found confirmation from noone else but Paul http://groups.google.com/group/ultimaker/browse_thread/thread/7511401e952b586c/2c7df6ff0e8dca94?show_docid=2c7df6ff0e8dca94&pli=1. Note to self: use more Google BEFORE. It wouldn't hurt, though, if Netfabb manual didn't describe features that aren't implemented/are not working.
