I also had problems with my temperature control lately. The problems I had were a little different but it resulted in sudden stops in the print... With the printer attached to RepG26 and ticking on the printer head with my finger I saw the temperature jumping from 20 (room temp), up to 60, back to 5 degrees and back to normal temperature again in the end. During a print it will take some vibrations too which resulted in a failed print. Newer firmwares react differently on temperature changes. Older firmwares only cool down the head when a strange temperature was measured, newer firmwares stop printing at the point where the (too) high or low temp was measured.
I replaced my sensor two days ago and it shows good temperatures again. I'm able to print again!
Daid 303
I'm reading that you started out with an ATMega1280. Do you have one of the early workshop machines? Because those machines are quite different.
I've never seen the firmware do moves that are not in the GCode. But the software has been moving very fast for the last few months. Even the RepG25 you mention is quite old already.
As for the thermocouple, when it fails, it's almost always a short in the wires. Check if the insulation is intact, in some cases this is damaged at the hot end side.
