I found the left stepper very hard to get the right tension on since it is not pulling straight on the belt.
So I drilled a hole on top of and behind the left stepper motor - and used a screwdriver with a piece of wood in between to gently "wedge" the stepper down. That helped a lot.
I have also given all the belts "Cyclo Belt Dressing" - that is a gluey grease that keeps your belts in "better than new" condition.
Daid 304
Did you check both the sort and the long belts? To tension up the short belts you need to unscrew the motors a bit and then push it down and screw it tight.
Also, step motor driver current is something you could check:
http://wiki.ultimaker.com/Electronics_b ... or_drivers
