Posted
· UM Original Doesn't Connect, Stepper Drivers Bad
This sounds like you wasted the 12v regulator on your board (maked IC1), did you have the printer turned on for long periods of time without the fan blowing on the electronics? eg. while you were adjusting the stepper drivers?
If you have a multimeter, try measuring the voltage across the pins of the 12V regulator component... if you turn the board/printet so that the 12v regulator is closest to you, it should be 19V between the middle and left pins and 12V between the middle and right pin...
tommyph1208 55
You may want to have a look at these other posts:
http://umforum.ultimaker.com/index.php?/topic/3426-classic-ultimaker-just-died-only-green-led-lights/
https://groups.google.com/forum/m/#!topic/ultimaker/voS2qlOs8-k
