What is it that is bothering you? Are the bottom 2 images of the bottom layer? If so you might want to check your leveling a little. You want the bottom layer to squish a little into the glass but not too much such that the plastic can't get out. Getting leveling accurate to 1/4 of the first layer is critical. So if first layer is .3mm (default) then you need accuracy around .05mm (1/2 of piece of paper). If first layer is .06 then you need accuracy of about .015mm (1/6 of piece of paper).
In top left picture there is a bump. If that is a problem you can try the "cool head lift" option or you can print 2 models at the same time so that one model has time to cool down while the other is printing.
Thanks fo taking the time to reply GR5
The top two pictures are the first print at 0.01, the bottom two pics are a second attempt on a finer setting 0.06
The lump in the middle should be a curved raised bump, the link in the original post supplies a photo showing the zbrush smooth model, the whole thing is supposed to be smooth hard surface, but looks like chocolate cake.
gr5 1,873
