AFAIK, Octoprint does not display (or know) the filament diameter. I guess where it says "Filament: 1.93m", it is telling you it will use 1.93 meter of filament.
The number you can fill in on the Control tab is only for manual extrusion (and it is not a speed, but a length).
Octoprint basically copies the gcode file directly to the printer, without altering it. If it prints directly from Cura (over USB), it should also print with Octoprint (over USB).
Yes now that I look at it you are right. That is the length of filament to be used.
I've printed both files with cura over usb with no problems. Wonder why I'm having trouble with octoprint with both files.
ahoeben 2,047
