Posted · Poor quality base layer help
Hi Guys,
I received my ultimaker about a week ago and have been printing various things testing it out. Once thing i am commonly getting is a very poor quality layer where it is in contact with the glass build plate? Is this a levelling issue or should i be changing some of the settings in Cura to try and stop this?
Thanks
Russ
    Hey Russ
    It`s most likely a levelling issue, although could be a few other things too. If possible try to upload some images. If you are using glue, don't use too much! And also, set your bed temp to 60 degree, instead of the standard 75 degree. Are you using the ultimaker blue which ships with the machine too ?
    Welcome to the forum :)
    Hi welcome to the forum,
    Could you give us the print settings you use? Temperatures etc?
    It helps printing the first layer at 230°c and having a well leveled bed is a big plus for a good first layer
    Hi guys thanks for the reply. I am currently using white filament, and the standard settings in cura, 260 nozzle temp and 75 bed temp for the entire print. Looking at Cura how do you specify different temperatures for the base layer? I have also tried levelling the machine numerous times using a sheeet of paper, is there a better way to do this?
    Thanks
    Russ
    Are you using ABS? 260 for PLA is way too high, lower it to 210-230. Change your bed temp to 60.
    There are more CURA settings under the " advanced tab ".
    Where in the UK are you russ?
    Hi Skint,
    I think there was a typo before i am printing at 220 with PLA. I will try change the bed temperature to 60 and see what happens. Just have to deal with a blockage first. I am in Surrey, where abouts are you?
    Russ
