Problems in Cura 14.07
bawflinger
Posted · Problems in Cura 14.07
Hey, first post. Got my machine and been printing for a couple of weeks now. Had just started getting to grips with the full settings and today was printing at .6 happily. Update 14.07 came through, so I stuck it in and tried a test print. I Adjusted all the settings I was getting used to in full settings on a part, which before took 1.2 hrs to print at .6 and a speed of 50. Firstly, it was telling me it would print in 5 mins. So I tried that and it was like watching a mechanised tube of toothpaste moving around. Basically, as low a quality as you can ever get and the part failed. I tried every setting over and over, even re-starting the program and nothing seemed to get me out of low quality settings. Print time varied from 5 mins to 13 mins, so its adjusting something. In basic, its printing in high quality, but I really need the .6 for what I'm doing. Any ideas?
    Can you try:
    "Expert -> switch to full settings"
    "File -> Save profile" (Store it somewhere, so we can look at it later to see what was wrong)
    "File -> Reset profile to default"
    Try what it says after that. It that fixes it, then some setting in your profile must have been messed up.
