Hi Dude, (cool name by the way) : )
Thanks for your response; i printed another test with an overhang to better understand whats happening and watched it in action.. i realized right away that my question was silly, and that it was in fact printing solid above the support structure (and not infill), the spacing between the support though simply meant that the first layer directly above the support will be be loosely connected therefore creating a rough looking surface.. with more research on the subject i realized thats normal in all 3d printers.
But what's puzzling me the most is the fact that the first layer above the raft structure (although the raft is more solid) the first layers above the raft is much smoother..so whats the difference??
And if this is a universal issue (printing with support structure), why is there no option in CURA to start building the support structure in lines like it does (to save material), and then on the top final layers of the support structure to print a solid layer (which would have the rough edge on the under side like in my case), and then on top of that the same type of raft construction, these 3 elements would be part of a support structure that would be underneath over hangs. This way the support structure would be easy to separate from the model (just like removing the base raft from the model) and would give the overhang a nice clean surface where it touches the support structure....? or does this option exist??
Thanks,
pm_dude 27
Hi Akila,
Welcome to ultimaker! Glad to read your are enjoying your printer
Could you post a picture of the overhand? It will help see what is happening. You will see over time, that anything requiring support are highly affected by it. Contact with supoort is almost always bad. Some material react better than other.
