Some improvement. I can move the extruder by hand yes. I slackend off the belts and made sure the rods XY were square.
Once the motors are warmed up, it seems I get some sticking, if I use software to control the movement and jump +10 in X or Y I get a momentary pause/stick near the edges of the build area.
joergen 2
can you move the XY blocks by hand when the UM is powered down?
I would assume that it's also difficult by hand, and that your XY isn't square: http://wiki.ultimaker.com/Ultimaker_rev.3_assembly:_Extrusion_head#Parts_needed_in_this_section_3 step 9 forward
