Posted · Hotend Heat Up Intermittent Lag
Hi guys,
I have a UM1 and am facing an issue with hotend:
--When i start print, I manually push up the temperature to 200c (controlled via laptop).
--However, it usually takes sometime before it actually starts heating up. So on the temperature graph in cura, there will be a long flat line (at room temperature), then suddenly / randomly it will heat up.
Sometimes everything will be fine. I raise the temp in CUra, and it heats up immediately.
What's the best way I can I can trouble shoot to see what the problem is?
Thanks!
