Head Hitting the sides
Labern
Posted · Head Hitting the sides
Hi
when I was printing something the other day that was quite large, the print head hit the right side when doing the skirt. it kind of kept going fine so i just left it as after the skirt it was fine.
the thing that puzzled me is that it was blue in cura not grey and was central on the bed.
I have now just started to try and print one of those wallets from XYZ.
It was grey when i loaded it and after a lot of playing around i found it went blue after turning the skirt off.
I kind of moved it away from the right side as much as i could as its very wide but when i started the print it hit the front and the belt jumped a tooth with a bang.
So, If the item in cura is blue is this meant to mean its ok and won't collide or is it just saying yip thats on the glass or do I have a setting off?
Thanks
