Nozzle change
thomas-roager
Posted · Nozzle change
Hello folks
I have an ultimaker with an E3D v5.
I have been running with okay prints, just not the Way i liked it, so i changed my nozzle size for faster prints.
I changed from 0.3 to 0.35.
And when i did that i tried to do a print, and Lines were Way off on the new size.
So my question is, What should i do when i change my nozzle?
Do i have to recalibrate my extruder and so on.
Hope you guys Can help :)
If needed i Can Uploade some pictures.
    The only thing you should have to do is tell Cura that your new nozzle size and set the shell thickness to a multiple of your nozzle size.
    Perhaps the new nozzle has a bad shape? Perhaps the tip isn't flat?
    (I change nozzle sizes often)
    Then i dont understanding this print :/
    It looks like over extruding and then under extruding.
    foto 3
    foto 2
    foto 1
