Thanks!! I have only gone through the initial calibration once (everything has been working excellent), but if i am correct, during the reset steps, it will ask to feed the filament way before the hot end begins to heat up, therefor jaming in filament first slowly, then fast. And i am not sure how you mean to remove (or pull) the filament from where? it is fully loaded and firmly grasped by the feeder in the rear. Silly accident, but still can't figure out how to do this when there is only the initial set-up function available. (no maintenence or change filament functions available)
IRobertI 516
Go through the steps again until it starts heating up the hotend. Before it finishes warming up all the way just yank the filament out (if the hotend is 90C or more it's easy to pull the filament out). Once you get the filament out of the hotend you can shut down power, remove the filament all the way and start over once more.
