MAXTEMP BED error report and Ulticontroller hangs
fons
Posted · MAXTEMP BED error report and Ulticontroller hangs
I have installed a heated bed on my Ultimaker Original (with Ulticontroller) .
The heated bed is bought a few weeks ago from 3Dprinting_HK, you all know .
Upon installation, I added my modified printer as a new machine into Cura 14.07 upon which the 'default firmware' for this configuration (Ultimaker Original / extruder drive upgrade / heated printer bed(self built) ) has been installed .
Then I get this reading on the Ulticontroller https://www.flickr.com/photos/128060614@N02/
and the Ulticontroller hangs .
I can achieve communication again only when I install the firmware for a printer without heated bed ( machine settings in Cura ) .
in the other case I get a message : Failed to write firmware. 'Timeout'
I have read some similar topics on this issue, this means the problem is known and clear . Is the answer also clear ? What causes this ? How can I fix the problem ?
Thanks !
Fons
    To Tommyph,
    I may be confusing but I have posted this also in a new topic in which a part of the problem for me is solved, although I can still not print . Maybe it works for you all the way ?
    http://umforum.ultimaker.com/index.php?/topic/6008-ultimaker-dead-after-installing-heated-bed/?view=getnewpost
    Fons
