thanks daid.
any good soruces for cheap 3mm plastic ?
also is there a benafit to using 3mm over 1.75?
thanks.
Ian
thanks daid.
thanks.
Ian
http://reprap.org/wiki/Printing_Material_Suppliers
http://reprap.org/wiki/Filament_supplier_reviews
http://reprap.org/wiki/Mendel_Buyers_Gu ... _Suppliers
the difference between 1.75 and 3mm is fundamental. if you have a 3mm filament printer, you can't use 1.75 and the other way around.
you can change your setup, but it requires changing the extruder mechanics, and the hotend, in other words, it's a lot of hassle.
I've used ultimachine.com and they seem pretty reasonable, with a fair selection of colors. I haven't printed anything yet, just got my kit today.
Daid 298
The UM requires 3mm filament.
I think I'm half way trough my 2.3kg spool. With many objects, but I print a lot of small things. So it's kinda hard to say. The 2.4kg will last you more then enough time to figure out how fast you spend the filament and when you need to order more.
