surfinitup 0 Posted October 25, 2014 in dual extrusion merge using SolidWorks Hi, I can't get the dual extrusion merge feature to work. I started from a solid model in SW, cut half of it off and saved it as 1.STL. Then I cut the opposite half from the exact same SW file, and saved it as 2.STL. When I import them and select 'dual extrusion merge', the two models merge in the wrong orientation. I've tried it with a few different models, and there doesn't seem to be a consistent offset, it seems random. Any help would be greatly appreciated. Thanks! Share this post Link to post Share on other sites
nick-foley 4 Posted October 26, 2014 in dual extrusion merge using SolidWorks My first guess is that Solidworks would be saving with the origin as the centroid of the exported portion of the model. Try creating a reference coordinate system in SW and using that when exporting your STLs? Share this post Link to post Share on other sites
highlea 0 Posted September 28, 2015 in dual extrusion merge using SolidWorks Hello Just had the same problem and tried using defined reference systems but did not work. Finally discovered that you need to tick the following box in the STL output options window.: 'Do not translate STL output data to positive space' I also had a defined coordinate system selected, but think it should work with the default. Share this post Link to post Share on other sites
