Cura speed settings
shiremog
Posted · Cura speed settings
I'm confused!
In the "Basic" page of settings there's a "Print speed setting". In the "Advanced" page, there's a range of speed settings. Which applies? How do the settings on the two pages interact?
    Travel Speed is the speed of the head when moving from one part to another (not printing) --> Not related to print speed
    Bottom layer speed is the speed at which the first layer is printed --> Not related to print speed
    Infill speed the speed at which the infill is printed (the inner pattern): if 0 then it's the same speed as the print speed
    Outer shell speed the speed at which the outer shell is printed: if 0 then it's the same speed as the print speed
    Inner shell speed the speed at which the inner shell is printed: if 0 then it's the same speed as the print speed
    So if you specify other values than 0 for the three last speeds it will overrun the value you entered in print speed. I usually leave them to 0
