Dim3nsioneer 558
A quick check showed that the plugin gets the temporary file from Cura like this. There is not much I can do from the plugin side... Daid?
Yes, most likely a bug on the Cura side. I'll check to see where this can go wrong.
So if i copy the first lines from the normal gcode it would be useable thanks for the feedback
Daid 306
Yes. The UM2 looks at the "MATERIAL" lines to know which hotends (in case of dual-extrusion) to heatup. With no values there, the UM2 decides that it does not need to heatup anything.
