Posted · turning off UM2
There shouldn't be a problem leaving the filament in there, with the exception of WoodFill, which I would recommend that you remove after you're done printing. Not because it will hurt anything sitting in there cold but because it's easy to forget the machine is heated up when you're fiddling with settings and WoodFill doesn't like being warm for long periods of time.
